Brief Description: Left wing rib, aft spar priming, plus...
Today all of the left wing ribs, aft spar and aft spar doublers were primed. While I was waiting for the epoxy primer induction period to pass I also assembled some right wing components for a fit check and to see how well it went up the basement steps, see image 1. After the priming session was over I installed the support angles on the posts of the wing assembly fixture. Image 2 shows one support with the electronic level on top. Image 3 is a close up of image 2, well levelled!
